01' 90 Scrambler problems help.
Old Aug 5, 2008 | 09:39 AM
SherpaT350's Avatar
Default 01' 90 Scrambler problems help.
The scrambler quit , it has spark and turns over fine. Put in new plug for the heck of it and sprayed some starting fluid into the sparkplug hole to see if it would start.No go,it won't even fire.What the heck,it has spark and fuel .
Any ideas,
Thanks,
D.
Old Aug 5, 2008 | 11:01 AM
T-BEEF's Avatar
Is the exhaust plugged water or mud . How did it die what were the circumstances and is there lots of compression
Old Aug 5, 2008 | 11:34 PM
Check stator for dirt and mud,MOST of the time no spark on 50 and 90 are stator related. clean,pull flywheel if have puller,clean pulser(little plastic piece with 2 wires) out side of flywheel area. Good luck
Old Aug 6, 2008 | 12:28 AM
SherpaT350's Avatar
It HAS spark , I am thinking somehow the ignition timing got out of wack and I will check the exhaust also.
Thanks for the input,
Raz
Old Aug 6, 2008 | 01:08 AM
SORRY getting blind, check compression since you said had fire and I overlooked! As posted above see if pressure coming out of exhaust when turning over. Had one customer open his exhaust with a long punch, noisy,but less restrictive.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
