Help Kazuma 90cc will not start
Old Aug 5, 2008 | 11:50 AM
Brian Heard's Avatar
Default Help Kazuma 90cc will not start
I have a 90cc kazuma falcon. It sat up for about 6 months. When I went to start it, of course it would not start - carb gummed up. I replaced the carb with a new one. It's got great spark, but for some reason the gas is not making it's way to the intake. The plug is completely dry. I switched carbs again - another new one. Still no gas in the intake. It will fire off when a spray starter fluid up until it burns up. So I know its not a spark issue. It just does not seem to get gas in the intake.... almost like no suction. The ATV has less than 10hrs running time on it. Please help, this is driving me crazy and my 7 year old daughter wants to ride.
Brian
Old Aug 5, 2008 | 12:33 PM
luvmysxs's Avatar
i bet you buck all it needs is a valve adjustment.
Old Aug 5, 2008 | 02:58 PM
I have heard that. Do you know how, or a reference where I can find this info? Is it the valves that creates the suction for the fuel? thx
Old Aug 5, 2008 | 03:40 PM
luvmysxs's Avatar
send me your e-mail address and i'll send you instructions on the valve adjustment. no the piston moving on the intake stroke (down) creates the vacuum allowing the air fuel mixture into the cylinder. more than likely if your valves have never been adjusted before they will be to tight and are not closing all the way, allowing the mixture to escape on the compression stroke and also causing low compression. luvmysxs@yahoo.com
Old Aug 6, 2008 | 05:46 PM
Thx so much. I sent you my e-mail. I contacted Kazuma's helpline and they keep saying the same thing over and over.... "dirty carb". Even though I replaced it w/two new ones. thx again
Old Sep 30, 2019 | 10:37 AM
Ste Dymond's Avatar
Default None strter
Id say if its totally dry , but runs of easy start till it burns off ,id firstly make sure its not fuel tap on tank bunged up if the carb was theres a chance tap might be.?make sure theres fuel coming through the pipe,pull pipe of the carb turn the tap on see if fuel comes out
Old Apr 20, 2024 | 11:53 AM
Gshell1786's Avatar
Can I also get those instructions pls on valve adjustment thk u email is gshell1786@gmail.com
Old Apr 21, 2024 | 03:16 AM
That post is from 2008 doubt if luvmysxs is here anymore.
Set the piston to top dead centre on the compression stroke. Remove valve covers, check clearance between adjuster and valve stem is about 0.002" with a feeler gauge, if it is much less, you will be loosing compression. Too much and you get noisy valves and a slight loss in power. The 0.002" is a bit of a guess, but I have the Kazuma manual and, though it tells you how to take the engine apart, it doesn't give settings. Other Honda Cub clone valve settings seem to vary between 0.0015" and 0.003"
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
Bigredjeep
Aug 24, 2015 12:27 PM
merryman
Jun 27, 2015 03:31 AM
1000gade
May 27, 2015 12:37 PM
hot_shoe_cv
Oct 13, 1999 02:16 PM
