Steering pulling HARD to right randomly...
Old Aug 7, 2008 | 05:33 PM
thefed's Avatar
Default Steering pulling HARD to right randomly...
I've read other posts, and it seems this means I need to replace hub fluid and try again. Well, I cant replace hub fluid in right hub because drain plug is stripped...working on that dillemma now. I already changed fluid in the left before the problem began. This problem 'seems' to go away when I flip to 2wd, but it isnt happening often enough to diagnose...but it'll happen at least once per minute of tooling around in the back yard.
My other suspicion is the torn CV boot on the left side. It was torn when I got it, and I havent gotten around to replacing the entire shaft (I have it sitting in my garage...i decided to do the whole thing because i had no idea how long boot was torn b4 i bought bike). Could the CV joint cause this? If so,maybe i'll do that first?
Old Aug 7, 2008 | 05:44 PM
kukerdan's Avatar
is it pulling only in 4wd?
Old Aug 7, 2008 | 06:36 PM
user493's Avatar
Moto Psycho
It sounds like the hub is locked in when it shouldn't be.
Old Aug 7, 2008 | 10:05 PM
thefed's Avatar
i guess my main question is COULD this be caused by a faulty UV joint?
Old Aug 15, 2008 | 02:17 AM
01 SCRAMBLER's Avatar
i bet it is a rock in the cv joint happen to me had to replace bearings and all
Old Aug 15, 2008 | 07:34 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
could be the cv, or bad bearings. the awd could be sticking on in that one side or other side isnt locking in when when the awd is pushed on.
GregM
Mar 6, 2018 06:53 AM
toonces
Oct 19, 2015 02:21 AM
Gtsordo
Jul 22, 2015 01:27 PM
mdrkcckv
Jul 22, 2015 09:10 AM
1966F100
Jul 12, 2015 03:01 AM
