98-99 blaster
Old Aug 8, 2008 | 02:15 AM
rhonda350's Avatar
Default 98-99 blaster
My friend has a blaster and it doesent want to start up no more. At first he hat it running for 5 min then it killed. It got gas everything new plug, oil, airfilter ect ect. Then he tried to start it again it starts for like 3 sec and dies again. What do u think is the problem. We think it is the carberator.
Old Aug 8, 2008 | 07:23 PM
91Warrior357's Avatar
prolly has a stuck float
Old Aug 8, 2008 | 08:13 PM
ZZTOP's Avatar
i have the same problem last week
one of the reed valve petal was broke first time i see that
i don't no it's your problem
good luck
Old Aug 9, 2008 | 03:01 AM
hotblooded's Avatar
Check the compression, at least rule that out.
Old Aug 9, 2008 | 03:34 AM
taggart's Avatar
i would check the reeds . they can break from time to time in blasters . take off carb and unbolt carb manifold block you will find them in there .. best to use carbon fibre ones if you are replacing them .
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
