97 warrior 350 problems
Old Aug 5, 2008 | 06:43 PM
abmobil's Avatar
Default 97 warrior 350 problems
My buddy has the Warrior.
It ran fine last week.
This week we went to start it, and it ran for awile in the garage ,but then it died.
We kept restarting ,and it would run for a sec ,and then shut off.
We sprayed starting fluid into the intake ,and that would keep it running until we stoped spraying.
I pulled the fuel line off of the fuel selector valve ,and it is flowing plenty of fuel to the carb.
Any ideas what may be wrong?
We also replaced the spark plug ,but it changed nothing.
Thanks.
Old Aug 5, 2008 | 08:06 PM
StngGT350's Avatar
does it run with the chok on?. well i would start by cleaning the carb really good. i had that happen to me and it was the pilot jet that was clogged. so give it a good cleaning. good luck!
Old Aug 9, 2008 | 03:36 PM
m16a2's Avatar
the float in the carb maybe stuck. Same problem happened with my warrior.
Old Aug 9, 2008 | 05:02 PM
mechanicock's Avatar
2^ on the carb cleaning, any minute peice of trash can clog a pilot jet orfice.
Old Aug 9, 2008 | 05:28 PM
cadillacdude1975's Avatar
that would be my guess as well. i bet it has sucked some trash into the carb and it has either caused the floats to stick, but id be willing to bet it has clogged up an idle jet. will it run while you are giving it gas?
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Reactant
Jul 16, 2015 10:29 PM
