700 transmission drain plug
Old Aug 8, 2008 | 01:07 PM
70judge920's Avatar
Default 700 transmission drain plug
I have a 07 700,changed the trans fluid and found that something has ground on the drain plug , chain? I ground the plug down,cleaned and replaced, does anyone have any ideas on why this happens,only has 600 mi.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Aug 8, 2008 | 02:49 PM
sheepdogMSP8117's Avatar
By stendori:
just an update on an old post that sheep smartly started im in the process of changing the trans. fluid and sure enough like sheep mentioned my draain plug is ground down and its because of the chain inside which is extremly loose. i dont now if it can be tightened like a cam chain or not(i'll go read the manual after) but im doubting it. just wanted to show you guys and maybe make you check on yours. im going to somehow either grind mine down or cut it down so it doesnt hit any more. here is a picture of the plug if it comes out.
greg74
Sep 10, 2019 03:03 PM
SDR-II
Sep 29, 2015 01:06 AM
Captjay
Jul 23, 2015 12:33 PM
Shifts
Jul 3, 2015 07:59 AM
bikedad3
Jul 2, 2015 02:15 AM
