Engine oil suggestion?
Old Aug 13, 2008 | 08:45 PM
jdreck's Avatar
Default Engine oil suggestion?
Currently own a 2008 sportsman 800 HO twin EFI. the manual recommends 2w-50 motor oil? only place that carries this oil is the polaris dealer.What is everyone else running in theres(any problems)
Old Aug 13, 2008 | 08:52 PM
Koerbs's Avatar
I would run the 2w-50. If you buy synthetic 5-30 mobil one and a oil filter from napa, its the same price as the kit from polaris, and that 2w-50 is usually expensive, so it isn't that bad of a deal.
Also, I have heard that lighter weight oils can tear apart the valve train under hot conditions. This is a reason why they recomend 50 weight oil.
Old Aug 13, 2008 | 10:08 PM
DITTO the Polaris oil change kit! If you love your engine USE the recommended oil!
Old Aug 13, 2008 | 11:38 PM
Koerbs's Avatar
Old Polaris Tech, is that rumor about the lighter oil weights and the valve train true?
Old Aug 14, 2008 | 01:03 AM
ABSOLUTELY TRUE, HAVE CAMSHAFTS TO PROVE! Anybody need any paper weights? have a box full of em! Have to admit though that some of my cams came from machines that looked like they had oil changes about every 500 hrs! Oil thick and black like syrup. Just regular maintenance and any engine should should last.
KimSJoh
14
Jul 18, 2015 07:20 PM
clsharky
Jul 13, 2015 02:07 PM
cSchwartz
Technical and How-To Articles
Jul 10, 2015 08:06 PM
Chocobamofo
Jul 10, 2015 07:46 PM
MNatv89
Jul 7, 2015 11:36 AM
