05 Kodiak Speedo problems
Old Aug 14, 2008 | 10:35 PM
misterfixit2k's Avatar
Default 05 Kodiak Speedo problems
I have an 05 Kodiak 450 that recently started displaying varying speeds. Even though I'm cruising along at a constant 15 mph the speedo display jumps all over the place like: 0, 8, 12, 7, 14, 3 ... etc. Anyone else have this problem, or know what it may be. It appears that the odometer isn't affected.
Thanks,
Old Aug 15, 2008 | 03:19 AM
HeftyLefty's Avatar
The speed sensor may be wacked up. Or the wiring to the speedo may be corroded or loose. I looked up the sensor at www.mrcycles.com, and the sensor is located on the secondary pulley shaft, I think.
You can find it under Electrical. It lists for $57.00.
HTH
Old Aug 15, 2008 | 10:43 AM
CraZySteve's Avatar
Not sure what it could be... but here is the link to the Factory Yamaha Manual [img]i/expressions/face-icon-small-smile.gif[/img] Should help ya out!
Here is the link w/instructions on how to Download a copy of the 03-06 Kodiak 450 Manual.
http://www.savefile.com/files/74511
1. Click the link in the Message
2. Scroll down to the Section in the BLUE Box that says "05-06 Kodiak 450" and Click "DOWNLOAD FILE"
3. Your download SHOULD start...
IF NOT
4. Scroll down to the Bottom.... where you will see
" Your download should begin shortly.
If it does not, try <u>Download file now</u>
lightninboy
May 16, 2021 09:52 PM
RedRancher
Oct 15, 2020 01:45 PM
txpedsrt1
Feb 3, 2017 08:07 PM
Desimation2k8
Jul 17, 2015 12:37 AM
RedRancher
Jul 10, 2015 06:36 PM
