Polaris 700 pulling to left
Old Aug 20, 2008 | 01:48 PM
Knadams78's Avatar
Default Polaris 700 pulling to left
Hey everyone I need a little help please. I ve got a polaris sportsman 700 2007 model. I've notice, just recently, that when I ride it has developed a strong pull to the left. I have to keep adjusting the steering to the right to compensate. Took it to the dealer and they said the alignment looked fine. tie rods are not bent. Air pressures are good. Dealer couldn't find the problem. I think it may be the bearings or CV joint but Im not sure. Left rear tire feels like it is catching on something. Strong vibration noted from left rear at slow speeds. Any Ideas on what I should Check and where I should start. Other than finding a new dealer? Any help would be greatly appreciated.
Old Aug 20, 2008 | 02:43 PM
big c's Avatar
check the cv loints and bearings sounds like a dry cv joint check for ripped or torn boots
Old Aug 20, 2008 | 04:01 PM
fubar's Avatar
Are you sure it isn't going in to 4x4? They will do that on hard packed surfaces. Mine will go in to 4x4 all on its own when it is really humid out.
Old Aug 20, 2008 | 10:48 PM
Plus if back tires have different air pressure will cause pulling and will seem like alignment problem. Good luck
MikeyBoyesq
Nov 27, 2020 02:44 PM
WilliamBos
Sep 30, 2015 08:08 AM
wannabe32
Jul 7, 2015 11:30 AM
Biggieshortie89
May 26, 2015 08:01 AM
Oneidgoof
Jun 14, 2001 03:06 PM
