Alpha Sport quad running problem
Old Aug 21, 2008 | 02:30 PM
harleygreyone's Avatar
Default Alpha Sport quad running problem
I have an Alpha Sport LG-90 quad that has a problem running. It starts and idles fine but when you give it gas it cuts out. I have done the following;
Replaced plug
Replaced coil assembly
Cleaned out carb
Cleaned out fuel line
Could there be something in the electrical system?
Any other suggestions would be helpful. Thanks.
Harleygreyone
Old Aug 21, 2008 | 09:26 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum harleygreyone! [img]i/expressions/face-icon-small-smile.gif[/img]
Does using a little choke help it any? If so turn the fuel screw (the one on the bottom of the carb thats almost impossible to get to) out 1/2 of a turn and try it again. I use a long thin pait of needle nose and get about 1/16th of a turn per grip. If it improves turn it out another 1/2 turn. If its a 2 stroke the air screw is on the side of the carb and will have the same effect.
Old Dec 15, 2008 | 06:29 PM
BRETERNITZ's Avatar
I am hoping to connect with Harleygreyone. I am new to this site & I don't have any help for your issue, but back on 8/21/08 you wrote in with a problem on an Alpha Sport 90. I am having exactly the same problem, and I was wondering if you were ever able to find what the problem was. Mine is a 2001 Alpha Sport 90 lg, it has an electric choke & I was thinking maybe something was sticking with it. If you were able to find a fix to your problem I would appreciate any info. you would share.
thanks
DTroyer01
Jul 3, 2015 07:34 AM
VascoConroy
Jun 12, 2015 10:30 AM
ZJnut
Dec 30, 1999 08:33 PM
pancake
Oct 21, 1999 10:43 PM
RidE
Aug 6, 1999 02:34 PM
