Winch Solenoid Placement
Old Aug 21, 2008 | 03:34 PM
Rolly's Avatar
Default Winch Solenoid Placement
Just wondering if anyone could help me out with where to put my winch solenoid. I have a 2006 Polaris Sportsman and a 2800lb. Bear Claw winch.
Thanks.
Rolly
Old Aug 21, 2008 | 04:11 PM
Koerbs's Avatar
It should be pre wired for a winch. There is a spot that the solinoid goes in the pass fenderwell be the frame under the headlight.
Old Aug 21, 2008 | 06:27 PM
hunt1940's Avatar
viper tells you to install it in the back compartment ,so it is closer to the battery, atleast thats what i did today.
Old Aug 21, 2008 | 07:08 PM
Rolly's Avatar
Thanks for the help guys. I found the wiring that was already there and the plate to mount the solenoid on. Now I just have to find out why the winch gears are "skipping". It won't even pull my quad across the yard in neutral. The winch motor runs, but it doesn't pull any weight. Just seems to skip.
Old Aug 21, 2008 | 08:09 PM
Gee3's Avatar
Is the freewheel clutch fully engaged?
Old Aug 22, 2008 | 10:50 AM
Rolly's Avatar
Yes
Old Aug 22, 2008 | 10:53 AM
Mikka's Avatar
check for reversed wire on the actuator.
Old Aug 22, 2008 | 11:06 AM
GunnSmoke's Avatar
i had the case of my winch crack, it would pull fine without any load but once you had a load it would pop pop pop, my crack formed by the free spool lever, not saying it's the same problem just something you might want to check
Old Aug 22, 2008 | 01:07 PM
Rolly's Avatar
thanks for the replies. I know the wires are on properly, I'll check for some cracks.
Johnny Mac
Aug 15, 2019 03:13 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
EIF
Apr 20, 2017 07:15 PM
Jackg17
Sep 26, 2015 09:30 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
