Badger
Old Aug 21, 2008 | 09:57 PM
4WRIDER's Avatar
Default Badger
My 1993 80 Badger will not start by electric start. Engine Spins fine, has 12v on battery. We can push it 2 feet while in gear & fires up immediately. Ant Help??
Old Aug 21, 2008 | 10:46 PM
cadillacdude1975's Avatar
Default Badger
seems like a connection issue with maybe the on/off switch and the start button.
Old Aug 21, 2008 | 11:42 PM
100's Avatar
100
Default Badger
could be the valves we have a raptor 80 and it had the same problem intake valve was to tight so i adjusted it and it started right up.
Old Aug 23, 2008 | 11:21 PM
4WRIDER's Avatar
Default Badger
The switches all work. It has spark, fuel & air. Will start after being pushed in gear after 2 feet, but won't start on electric start. (even with charger on) Thinking the starter is taking juice away from the ignition system????
Old Aug 24, 2008 | 08:52 PM
91Warrior357's Avatar
Default Badger
if you dont have any screwy connections id say you have a weak stator maybe. the engine spins faster when its push started vs the slower turning of a starter. a weak stator wont create a sufficient spark at how fast the motor is turning by the starter. the push start gives it just enough of a spin to make the stator turn fast enough to give the ignition coil a strong enough spark to ignite off of. but im not familiar with your atv and could be something else maybe.
Old Aug 25, 2008 | 11:38 AM
Terrellster's Avatar
Default Badger
I've been through this recently. I did all the adjustments and wiring checks and had 12 volts and all the things that have and will be mentioned. after all of that, I finally bought a *&%$% Battery and now she starts right up every time. But do check those valves my friend. They need attention once in a while.
Old Aug 25, 2008 | 11:46 AM
thenewshooter's Avatar
Default Badger
Check the valve gap. The same thing happens on my buddies Badgers. The valves need to be gapped every season. Other than that they are great kids quads. Enjoy!
armyman
Nov 2, 2012 05:19 PM
skeeterbug
Jan 24, 2005 05:24 PM
jrime
Dec 23, 2004 01:48 AM
RippinBlaster
Jun 22, 2004 08:39 AM
