'03 Blaster 200 won't rev
Old Aug 22, 2008 | 09:55 PM
thinman's Avatar
Default '03 Blaster 200 won't rev
Just bought 03 blaster. Stock. Ran well when son test drove, put new sprockets on and now will not rev at all. Will start and idle but will not rev. New reeds, head gasket, cleaned carb about 3 times, new gas, oil, plug, checked ex. pipe for blockage, can't get it to rev!!! Help!! They have a rev limiter? I don't think it is getting enough gas.
Old Aug 22, 2008 | 10:53 PM
270quadsportguy's Avatar
make sure the wires are connected to the tors system. If it acts like theres no throttle attached then id check the plugs at throttle and at top of the carb
Old Aug 23, 2008 | 04:51 PM
cadillacdude1975's Avatar
throttle cable working properly?
Old Aug 24, 2008 | 08:05 AM
thinman's Avatar
Not sure what that system is. There are wires connected to a switch in the throttle housing. Shuts off when switch is made. Yes, the throttle cable is working properly, as far as I can tell
Old Aug 24, 2008 | 08:06 AM
thinman's Avatar
throttle cable seems to be working properly. There is tension the whole way through the motion of the throttle. I'll check though.
Old Aug 25, 2008 | 11:43 AM
Terrellster's Avatar
RELEASE THE PARK BRAKE!
There's a sensor in the park brake mech that limits the rev when it's on. Once the park brake is released you'll be good to go!
I have 2 of them and have experienced this with me and other people starting them..... (Sorry about the caps, but criminy?.... there have been more threads on this one than I even know.)
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
