02 Pol Sportsman: U joints out?
Old Aug 28, 2008 | 11:48 PM
keruxjts's Avatar
Default 02 Pol Sportsman: U joints out?
My friend took my Sportsman 500 for a spin and it started pulling hard to the right... like the tire is flat but the tire is fine. Is that the u-joint? If it is, how hard of a fix is that? I don't want to take it to the shop because it will be there forever.
Old Aug 29, 2008 | 01:55 AM
user493's Avatar
Moto Psycho
It could be a U-joint, but if he had it in 4x4 the hub could be locked. If it is, back up while shaking the handle bars back and forth.
Old Aug 29, 2008 | 09:32 AM
keruxjts's Avatar
I will definitely try that. what about CV joints... do they cause the pull to one side or the other when they are out?
Old Aug 29, 2008 | 11:59 AM
Speeddrive1's Avatar
JF is right, back up and it should unlock the front diff.
Old Aug 30, 2008 | 10:12 AM
keruxjts's Avatar
I am being told that if the fluid in the hub is low, it will allow that wheel's 4 wd to engage and thus the pull hard to the right happens. Sound right?
Old Aug 31, 2008 | 11:18 PM
If fluid low and dirty can cause sticking problems on armature plate. If going into hub area REPLACE anyway(about 10 bucks) if not already bad WILL eventually wear and magnetize. U-joint rear driveshafts up to 98 models that are worn can cause erratic pulling,BUT since yours is an 02 model,has cv driveshafts and shouldnt cause hard pulling.
89Lt250r
Sep 7, 2015 07:53 PM
Ferhat Durakovic
Aug 26, 2015 07:04 AM
pro94lt
Aug 20, 2015 10:02 AM
toonces
Aug 13, 2015 12:40 PM
Peter_
Jul 18, 2015 07:06 AM
