02 Pol Sportsman: U joints out?
My friend took my Sportsman 500 for a spin and it started pulling hard to the right... like the tire is flat but the tire is fine. Is that the u-joint? If it is, how hard of a fix is that? I don't want to take it to the shop because it will be there forever.
If fluid low and dirty can cause sticking problems on armature plate. If going into hub area REPLACE anyway(about 10 bucks) if not already bad WILL eventually wear and magnetize. U-joint rear driveshafts up to 98 models that are worn can cause erratic pulling,BUT since yours is an 02 model,has cv driveshafts and shouldnt cause hard pulling.
