Help with 1995 Xplorer 400 brakes
Old Sep 5, 2008 | 11:26 PM
hesborn2fly's Avatar
Default Help with 1995 Xplorer 400 brakes
I bought this xplorer for cheap and trying to fix it up a bit. This thing came with a missing front caliper and associated brake line which I replaced. Problem now is with that stuff replaced and the whole system checked with new pads and new fluid I'm getting no pressure at the handle at all and no brakeing at any caliper. I've bleed all 3 multiple times correctly and even tried a vaccume pump which didnt help. Im at a total loss as to what is wrong, Could it be the master cylinder is bad? I even tried to shoot fluid up the lines via the bleed screws to make sure there full. Please help if you know any tricks. Thanks
Old Sep 5, 2008 | 11:49 PM
MECHANIKE's Avatar
try bench bleeding the mastercylinder,put a fitting on the end with a tube,put the tube into the master submerged in the fluid, pump the handle slowly till all the bubbles are gone,plug the line,see if you have pressure,be careful, wear glasses.if you have press.hook back up, bleed again furthest caliper first........
Old Sep 6, 2008 | 11:02 AM
Thanks for the tip, This is my first brake job on an atv. Only question is what to use for a fitting on the master cylinder if I don't have a bench bleed kit? I'm going today to replace the master cylinder anyway just for peice if mind.
Joe454
Nov 20, 2020 01:19 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
rockinkgin
Sep 25, 2015 01:52 PM
