Blaster Prob
Old Sep 12, 2008 | 11:38 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
Default Blaster Prob
So we have this old blaster. Did a rebuild a while back. The problem existed prior to the rebuild.
The problem is when your idling it will start to idle faster and faster. If you slightly let out clutch and let it start to grab it will lower the idle back down. Seems like a vacuum leak but, I've been all over this thing and can't find anything. Used carb cleaner to squirt around and find something to no avail.
Any suggestions???
Old Sep 12, 2008 | 12:03 PM
Raptor450's Avatar
It's probably sucking in too much air when you get it over 150 mph!
Sounds like you checked the cracks, but did you rebuild just the top end and the lower end, and did you use all new gaskets? The bottom end gasket could be leaking.
What happens when you idle it down withe idle screw?
Old Sep 12, 2008 | 07:59 PM
Koopa's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Raptor450
It's probably sucking in too much air when you get it over 150 mph!! ...</end quote></div>
Haha!! Like 180mph.
I rebuilt the top-end are worked over the bottom a lil' with few new bearings. Yup, used all new gaskets and actually changed head gasket twice. The thing is that it did this before I ever touched it. Leads me to believe prob maybe somewhere else.
I try messing with the idle screw but, the idle is so erratic it's hard to tell anything. It changes the idle like it suppose to but, it don't help the problem, it'll still get faster and faster until I let out the clutch a little.
Old Sep 12, 2008 | 08:13 PM
Raptor450's Avatar
Did you look at the reeds when you had it apart?
Old Sep 13, 2008 | 05:07 PM
Koopa's Avatar
Yup, replaced them. They look good.
I've been through this thing man, I can't find anything. I thought I had it about a month ago when my Dad mentioned the oil block off. Thought BAM!! thats it. Dude I got it from was too cheap to buy the kit and crafted his own including lots of silicon but, a lass it was not the issue.
Old Sep 13, 2008 | 07:02 PM
270quadsportguy's Avatar
probably has something to do with the tors system. blasters are hard to make idle IMO. i ended up going to a 45 piolet jet to get this one to idle and a lot of tinkering
Ahtatu
Sep 28, 2015 12:14 PM
BigCam
Sep 16, 2015 01:53 AM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
toonces
Aug 5, 2015 05:55 PM
