Wiring diagram for Polars Phoenix 2005
Old Sep 22, 2008 | 05:11 PM
DAN75's Avatar
Default Wiring diagram for Polars Phoenix 2005
I need wiring diagram for my Polaris Phoenix 2005. Anybody that can help me with this? I couldn't start my atv because my battery was death. I started it with emergency kick and it was running for about 20min and it didn't charge the battery at all so it bought charger and I charged it @ 2A for about 4 hours. Next day I was worming up the engine and after few minutes it died. I found out that my regulator was burned. What could cause that?
Old Sep 22, 2008 | 08:50 PM
If battery dead, shorting out/cant hold charge, could possibly cause reg/rectifier to fry. Current has to go somewhere.
Old Jun 23, 2009 | 06:58 AM
twister500's Avatar
Old post but just found it. My son had the same thing happen to his. I replaced the regulater (it looked melted like a bad light ballast) it was fine then. Then I found out that Polaris had a t s b or a recall on it I asked for a new one and as always they said nope if I had replaced it already.
Old Aug 2, 2011 | 05:10 PM
mwmehl's Avatar
Having the same issue with my sons Phoenix. The battery is not being charged and the headlights are dim. After about 1-3 starts the battery is in need of a charge. I need a wiring diagram and some knowledge as to how to test the stator, regulator, etc. If anyone can help I would greatly appreciate it! Can anyone give me some info on the recall?
Old Aug 2, 2011 | 07:48 PM
Welcome to the forum! Can't remember a recall? 6 years a little far back,but sounds like the regulator/rectifier needs to be replaced like the owner on the last post did! You might check with a local dealer if there was a safety bulletin or recall on this. OPT
Old Aug 3, 2011 | 01:24 PM
twister500's Avatar
I had that problem one more time since 09 and I replaced the regulator again this time with an aftermarket and it's been fine. I cant remember who I got it from but I think off of e-bay and it was alot cheaper then a stock Polaris one. When you pull the headlight cover off and remove the regulator smell it if it smells strange then it's toast nothing else to check after that.
txpedsrt1
Feb 3, 2017 08:07 PM
Tadej Dylan Vuzem
Jul 27, 2015 07:26 AM
tporath
Jul 11, 2015 12:31 PM
Chocobamofo
Jul 10, 2015 07:46 PM
tweeder
Jul 5, 2015 01:57 PM
