no power 03 600 sportsman??
Old Sep 22, 2008 | 11:41 PM
bwhntr4168's Avatar
Default no power 03 600 sportsman??
i drove it and turned it off and thats it done no power to the ignition and i have no electrical skills any help?? where do i start??
Old Sep 23, 2008 | 01:17 AM
79hugger's Avatar
Start first and check your battery to be sure it has 12 volts as well as the terminals for corrosion
Old Sep 23, 2008 | 06:13 AM
bwhntr4168's Avatar
i have 12 volts and the teminals look good !! all help appreciated !! thank you!!
Old Sep 23, 2008 | 07:43 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you check to make sure the kill switch isnt turned off or defective
Old Sep 23, 2008 | 10:12 AM
Kerbbirds's Avatar
Take the wires off the selenoid which is under the left rear fender, tighten the nuts under the battery wires then replace the wires, I;ve seen the inner nuts loose on several causing problems.
Old Sep 23, 2008 | 05:14 PM
bwhntr4168's Avatar
i checked those the dealer is tellin me its the stator??
Old Sep 23, 2008 | 10:05 PM
<div class="FTQUOTE"><begin quote>Originally posted by: bwhntr4168
i checked those the dealer is tellin me its the stator??</end quote></div>
Has the Ducati coil pack,notorious for failing! Is dealer sure?
Old Sep 23, 2008 | 11:07 PM
bwhntr4168's Avatar
well they werent for sure i found it it was the wire that runs from the solenoid to the ignition it was broke inside the rubber and it wasnt burnt?? thanks for everyones help it is very much appreciated!!!
Jmuddin284
Jan 19, 2026 07:16 AM
Cole Hadden
Jun 15, 2025 09:05 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
tweeder
Jul 5, 2015 01:57 PM
