1996 Sportsman 500 No spark
Old 08-31-2008 | 08:34 PM
bigjdog's Avatar
Default 1996 Sportsman 500 No spark
Hi, working on a Sportsman for a friend, they claim it was running fine, idling for a minute while fencing and just died. Haven't had spark since. I unplugged the black wire off the cdi to check switches, no change, also tried disconnecting the black wire from the hub safety switch, no change. Resistance between white and white/red wire from cdi trigger coil is within spec, air gap is correct. It's not getting any power from the cdi to the ignition coil. I also removed flywheel and inspected stator and flywheel, everything appears to be ok. I even swapped in another cdi that I had lying around which I think is good, no change. Anyone have any more tests I can perform, before just guessing the stator is bad? Thanks, Jared
Old 08-31-2008 | 10:23 PM
Also is charge coil (green,red,black with red stripe) within specs? Have had trigger coils good,but charge coil bad before! Grounds to coil good? plug wire good? Could possibly be coil,but usually pretty durable! Make sure raised spot on flywheel free from rust,can also cause spark loss. Only things can think of at this time! Good luck Keep us posted
Old 08-31-2008 | 10:40 PM
bigjdog's Avatar
Miniupdate-
Red to Green at CDI 4.7ohms
Black/red to Green 6 mohms (I'm assuming that's milliohms? My multimeter is an auto ranging unit, had a little m in front of the upsidedown horseshoe)
If that is an actual unit of resistance measurement, then I'd bet that's no good right?
I think the owners had the stator redone by RM Stator just a few months ago. Ground to ignition coil is good, didn't check the plug wire because I wasn't getting any power to the coil. Sanded down the bump on the flywheel when I checked the pulse coil's gap. Thanks for the ideas OPT. I'll keep researching.......
Old 08-31-2008 | 10:49 PM
Dont have schematic in front of me that shows specs on charge coil,but MAYBE some members have a shop manual handy! If not will look up at work on Tuesday. ALSO NO wires should show shorting to ground!
Old 09-01-2008 | 10:32 PM
bigjdog's Avatar
I would appreciate the info. greatly. I talked to the owner today and he said he did have RM Stator rebuild the stator, but he thought that they did not replace the bobbins/exciter coils. Hopefully your information will back up my idea that one of them is bad. If so, I'll get a pair on order from Ricky Stator asap. Also, no wires so far are shorted to ground.
Old 09-02-2008 | 05:23 PM
GRN-BLK 446 OHMS, GRN-RED 3.2 OHMS, W-W/R 97 OHMS,Y-Y/B 0.17 OHMS,Y-RED 0.17 OHMS Hope this helps on stator! Good Luck
Old 09-23-2008 | 11:34 PM
bigjdog's Avatar
Ordered new exciter coils from ricky stator, finally got a chance to put them and it runs good. Thanks for the information, couldn't have figured it out w/o it.
GregM
03-06-2018 06:53 AM
Jmuddin284
06-28-2017 04:59 PM
Johnclay
Utility ATVs
07-19-2015 10:00 AM
Countrygirl1976
Ask the Editor
07-13-2015 12:19 AM
sublime250
1) Engine problems..
07-11-2015 11:52 AM
Quick Reply: 1996 Sportsman 500 No spark
