Polaris Ranger Starter
Old Sep 26, 2008 | 09:24 AM
johnrdds's Avatar
Default Polaris Ranger Starter
2005 Polaris ranger starter will not stop turning. Unit is off and key is out--had to disconnect battery to get it to stop. Starts turning whenever battery is reconnected. Is this a problem in the ignition switch?
Old Sep 26, 2008 | 12:52 PM
HeftyLefty's Avatar
Probably. You may have moisture on the contacts closing the circuit inside the switch. Or, it could be a stuck starter solenoid, which is what sends current to the starter. Clean all contacts with WD-40 or similar. I don't think it's the pushbutton, unless the starter ordinarily turns over with the key off.
Old Sep 26, 2008 | 04:13 PM
johnrdds's Avatar
I disconnect switch from vehicle and starter still turns when battery is connected. I think I found the starter but where is the solenoid?
Old Sep 26, 2008 | 04:59 PM
MECHANIKE's Avatar
its right after the hot wire to the battery,little red wire coming out of it, if its anything like my scram...........
Old Sep 26, 2008 | 05:21 PM
MagnumPO's Avatar
i beat on mine with a wrench and it stopped. dont know why it worked i was just hitting it because i was mad.
Old Sep 26, 2008 | 10:28 PM
Yes good chance starter solenoid! Had ranger do same thing! Solenoid under seat in front of oil tank under metal flap. Just replace . Good luck
Reactant
Mar 30, 2022 02:08 AM
Gtsordo
Jul 13, 2015 10:38 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
tweeder
Jul 5, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
