01 warrior dies randomley
Old Oct 2, 2008 | 07:54 AM
zz8t's Avatar
Default 01 warrior dies randomley
i have an 01 warrior with boysen power reeds and a wisco power piston and in the last week or two it has started to just die randomley then if i try to start it it just turns over never goes
i have noidea what it is. it has no symptoms i have had this quad for 4 monthes and this is the first problem
pleas help i want to go to the sand pits by my house this weekend and i dont want to get stranded out there when the cops come
thanks zz8t
Old Oct 2, 2008 | 10:32 AM
Hebs's Avatar
check the vent tube hanging off the gas cap for debris... if that's clean, and the cap isn't clogged... rebuild the carb...
Old Oct 2, 2008 | 10:59 AM
Raptor450's Avatar
I would check the reeds first.........that has got to be the problem. Warriors always die when the reeds go bad.
If that's not it, check for wires touching the frame, especially at the rear near the CDI where the wire loops around the frame. What happens is the wire rubs the frame until the insulation is worn through, then the bare copper touches the metal frame, grounds out, then the engine dies. I've seen it happen on 2 Warriors.
Old Oct 2, 2008 | 03:19 PM
91Warrior357's Avatar
take apart your reverse shifter too you wouldnt believe how much dirt gets inside of there, theres a little wire that hooks to the back of it and a 17mm bolt on it just take it off and use some sandpaper to get it clean again, its like a little metal button. mine used to have a similar prob, sometimes it would have a hard time starting and it would idle good then just die out of nowhere.
Old Oct 2, 2008 | 05:21 PM
zz8t's Avatar
91warrior are you saying to just take apart the reverse shifter or should i take apart the shifter and chande the reads
Old Oct 2, 2008 | 09:00 PM
beatwarrior's Avatar
is this some kind of sick pratical joke ... since when do warriors come with two stroke motors... or .. when did fourstrokes come with reeds?........... ahh thats ur problem .. you put reeds on a fourstroke!!!
Old Oct 2, 2008 | 11:22 PM
Raptor450's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: beatwarrior
is this some kind of sick pratical joke ... since when do warriors come with two stroke motors... or .. when did fourstrokes come with reeds?........... ahh thats ur problem .. you put reeds on a fourstroke!!!</end quote></div>
Sorry, I couldn't resist.I love practical jokes! I couldn't stop myself.
Of course Warriors do not have reeds! Reeds only come on 2 strokes! 4 strokes have intake and exhaust valves that are timed open/closed by the cam. 2 strokes do not have intake and exhaust valves, just an intake reed valve that opens when the piston is on the downward stroke.
ultangler
Nov 30, 2024 01:35 AM
Pehter
Oct 3, 2024 11:00 PM
2many2ride
Sep 27, 2015 04:35 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
