HELP--- Polaris 90 problems!
Old Oct 3, 2008 | 09:31 PM
frognuts's Avatar
Default HELP--- Polaris 90 problems!
My kids 2002 Polaris 90 scrambler developed problems after being ridden in rain/mud. The next day it wouldn't start,so I drained the gas and it ran good for about 20 mintues. She said she hit a bump and it quit. It would start,but would die when the gas was given. Any help would be great.Thanks
Old Oct 3, 2008 | 10:29 PM
check air filter,also check behind right plastic cover to see if stator and pickup coil mud caked. I get a lot of these. Good luck
Old Oct 3, 2008 | 11:54 PM
frognuts's Avatar
What's the best way to clean the stator/coil? Air or contact cleaner? Also is the pick-up coil with the stator.Thanks
Old Oct 4, 2008 | 12:04 AM
BOTH! Pickup small module outside of flywheel.
Old Oct 4, 2008 | 10:09 AM
frognuts's Avatar
I went to work on it this morning and it started and ran fine again. Would the dirt in stator/coil cause it to run good some times and bad others. It seems strange ,see said she hit a bump and it acted up. Could be the dirt bounces around in the startor area? It's hard to fix when it's not acting up when I have it.
Old Oct 4, 2008 | 02:50 PM
I would check fuel system and carb for water. If running good until fuel shook up,could be water at bottom of carb? Water settle in the bottom of fuel tanks and the carb if present. Just a thought!
Old Oct 4, 2008 | 02:53 PM
mtpockets's Avatar
My 2-stroke Polaris 90ies were always giving me trouble. I sold them and don't miss them one bit.
I do see that the new ones are 4-stroke so maybe things have changed.
Good luck with yours.
Old Oct 4, 2008 | 03:41 PM
Evasiveone's Avatar
If the problem arises again I am also going to go with the stator. But it would only take a second to drain the bowel on the carb also. The symptoms you describe are classic symptoms of a stator heading south. Pull off the right cover and clean it out real well and see if that helps, but I bet you will end up replacing the stator to fix the problem 100%.
green giant
Jul 13, 2017 12:07 PM
DJS
Jun 28, 2015 11:34 AM
TJM
Jun 11, 2015 01:28 PM
Steven Bandemer
Jun 9, 2015 08:50 PM
hoopduerr
Jun 1, 2015 08:22 PM
