is big bear 250 good?
Old Oct 3, 2008 | 10:29 PM
myfirstquad's Avatar
Default is big bear 250 good?
i was gonna buy locally by me here is the desrip.
2007 Yamaha Big Bear 250, No Clutch 5 Speed With Reverse, Runs & Drives Great, Needs Nothing, Nice,
he said for upfront payment, it would be $1800 is it worth it? used
Old Oct 3, 2008 | 11:39 PM
mechanicock's Avatar
only thing i can think of is you may want more power later on down the road but i would not pass it up if you want to ride and you have the cash....
Old Oct 3, 2008 | 11:50 PM
my first atv so what the heck, it's extrmely cheap, so i'll take it [img]i/expressions/face-icon-small-happy.gif[/img]
Old Oct 4, 2008 | 01:18 AM
HeftyLefty's Avatar
Take someone with you.
Take a small jack and lug wrench.
Start the quad, rev it up check for black-running rich- or blue-burning oil-smoke.
Turn the handlebars straight, have friend check if wheels are pointed straight, and tires straight vertical . Turn bars fully left and right, have friend check wheels are fully turned each way, if not, quad may be wrecked and steering wacked up.
Jack front of quad up, have friend hold handle bars,grab a wheel and shake side to side and up and down. If loose, may be bad bearings, or hub, tie rods, steering bushing, or any number of things. Check both sides.
Remove tires and check brakes, look for excessive rust on rotor, does rotor turn freely, or does it bind?. Check both sides.
Do the same checks for the rear, look for signs of fluid leaks,if evident, seals may be gone;rear diff damaged from lack of fluid. Check cv joint boots for tears, If torn, look for rust or lack of grease.
If all these items check out, ride the quad and see if you like it. If they don't, I would walk away..
The last thing you want is to buy a quad for $1800 that you need to spend another 1-3 thousand dollars to repair.
Good Luck, hope it's a keeper.
Old Oct 4, 2008 | 10:39 AM
thi is the website http://chicago.craigslist.org/nch/rvs/860159602.html
i am assuming the big bear is the one on the top right? does it look in good condition to you?
Old Oct 4, 2008 | 08:19 PM
what does anyone else think of it?
tmoose
Jun 30, 2015 08:28 AM
rcappie4
Jun 21, 2015 07:33 PM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
neilbedwell
May 29, 2015 02:24 PM
