97 warrior 3530 problems
Old Oct 4, 2008 | 08:35 PM
91teggy's Avatar
Default 97 warrior 3530 problems
I have a 97 warrior 350 and it will start run for a min or two than will stall and not start back up for like a day or two...any ideas?1?1?
Old Oct 4, 2008 | 11:42 PM
Raptor450's Avatar
Need to check and see if you lost spark when it stalled. Probably did, so the 1st thing I would check is to remove the plug and see if it's firing. If it's not, then the CDI, stator, or the ignition coil could be bad, all of which needs to be tested with a volt/ohm meter. Also check the wiring harness in the rear at the CDI and make sure it's not bare copper wire rubbing the frame.
Old Oct 5, 2008 | 12:02 PM
QWODER's Avatar
pull fuel line off carb and make sure gas is draining through it.
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Reactant
Jul 16, 2015 10:29 PM
