04 kodiak 450 charing problem
Old Oct 5, 2008 | 07:03 PM
bmini's Avatar
Default 04 kodiak 450 charing problem
hi i have an 04 kodiak 450 that runs fine all day long and then once i start using the lights it kills the battery. i put a meter on the battery and when i start it the voltage does not go up at all no matter how high i rev it. also some times if i go above 40 for a little bit it will just die out and then i can not open the throttle at all or else it dies so i was thinking the carb needs a good cleaning. any help on either topic would be great thanks
Old Oct 6, 2008 | 09:13 AM
CraZySteve's Avatar
Sounds like the alternator/generator is junk as well as your battery..
Manual
http://www.savefile.com/files/74511
The link for the manual works but sometimes you just need to work it a bit...
1. Click the link in the Message
2. Scroll down to the Section in the BLUE Box that says "05-06 Kodiak 450" and Click "DOWNLOAD FILE"
3. Your download SHOULD start...
IF NOT
4. Scroll down to the Bottom.... where you will see
" Your download should begin shortly.
If it does not, try <u>Download file now</u>
That should do the trick [img]i/expressions/beer.gif[/img] [img]i/expressions/beer.gif[/img] [img]i/expressions/beer.gif[/img]
Old Oct 7, 2008 | 12:58 AM
bmini's Avatar
well so far i have fixed the charging problem. it ended up being a bad connection at the voltage regulator so i cleaned and greased it and all is well. as far as the carb issue i havent gotten to that yet.
Old Oct 7, 2008 | 03:30 AM
skj283's Avatar
that wouldnt be the first one to do that. a year ago my 450 wolvy did the same thing, i cleaned the connector and packed it full of dielectric grease and has worked ever since. a couple months back someone else with a wolvy like mine had the same problem, i think kodiaks and wolvys are basically the same so something is up with that.
Old Oct 8, 2008 | 02:34 PM
bmini's Avatar
everything is now fixed the carb had a nice chunk of something stuck in the main jet so all is well for now.
Old Oct 8, 2008 | 04:11 PM
CraZySteve's Avatar
Cool!
Now lets hope that battery lasts for ya! Hopefully you didn't draw it down that bad...
lightninboy
May 16, 2021 09:52 PM
RedRancher
Oct 15, 2020 01:45 PM
txpedsrt1
Feb 3, 2017 08:07 PM
Desimation2k8
Jul 17, 2015 12:37 AM
RedRancher
Jul 10, 2015 06:36 PM
