Drive tran noise
Old Oct 5, 2008 | 10:26 PM
Dug10's Avatar
Default Drive tran noise
I have '02 Sportsman 700 that I let a friend use a few weeks ago. When I went ride this weekend it is making a loud high pitch whine. It happens both in high and low range. I am wondering if something might have happened to the clutch. If it had a transmission I would think to start there.
Any other thoughts?
Old Oct 5, 2008 | 10:34 PM
Kerbbirds's Avatar
Take the clutch cover off and jack it up securely on jack stands and run it, you should tell where the noise is coming from. It does have a tranny, thats what does the high, low, and reverse.
Old Oct 5, 2008 | 10:43 PM
Dug10's Avatar
Good point I didn't think about the hi/low.
I'll try that tomorrow.
Thanks for the help.
Dug
Old Oct 7, 2011 | 01:47 PM
Steeves's Avatar
Did you figure out where the whine was comming from?
Old Oct 7, 2011 | 06:19 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i would think it would be winning in neutral as well if the clutches were an issue unless it needs to be under a load. did you check the tranny fluid to make sure it's full and does not have water in it?
speedbuff
13
Nov 11, 2020 10:16 AM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
bigbear350quad
Sep 11, 2015 12:40 PM
