help on carburator tuning on a shee???
Old Oct 9, 2008 | 01:06 PM
knear06's Avatar
Default help on carburator tuning on a shee???
me and a friend of mine rebuilt a 99 banshee and got running and sycronized the carbs thru the shotglass and fixed the idle problem but now when you rev it up smoke comes out more on one side exaust than the other so what do we do??? should we up the jets on the carbs?? also it has the stock carbs on it and we bored it .60 over so should we go with 34 mm carbs or can we stick with the stock carbs?
Old Oct 10, 2008 | 12:41 PM
Bobbyg's Avatar
Hey is it the left or right side ? IF ITS THE LEFT SIDE it may be your crank seal ,if its the right side only then your mix may be off , if you just want to tune/sync your carbs i use this http://www.bansheestuff.com/ca...linder-motorcycl2.html
Old Oct 11, 2008 | 02:23 AM
knear06's Avatar
it's on the left side thats not putting out as much smoke then the other side but on a warrior i owned you could crank up the fuel on the side of the carb just a little bit but i can't find nothing like on these i found out how to control the idle. and another question are banshee's known to put out not that much but a decent amount of smoke???
Johnny Mac
Aug 15, 2019 03:13 PM
freeman34
Jan 8, 2016 11:46 AM
CosmoM
Sep 21, 2015 04:57 PM
Alex G.
Sep 16, 2015 12:13 PM
Elkaholic
Sep 6, 2015 02:44 PM
