02 650 Prarie
Old Oct 9, 2008 | 06:32 PM
csmith33slb's Avatar
Default 02 650 Prarie
Wife turned over in about four ft of water.. Drained motor and flushed engine really good.. Replaced both spark plugs (Getting fire). Drained carb bowl (no water in fuel). Air box never had water in it. Wondering if it has a safety switch somewhere.. Any ideas ? Has compression
Old Oct 13, 2008 | 06:47 PM
Hayashi's Avatar
Yes, it has a tip over sensor under the seat. But it should reset itself when the quad is upside up. Are you getting fuel from the elec fuel pump for sure?
Old Oct 14, 2008 | 06:40 AM
I know the carb bowl fills back up with fuel. not sure if its getting pumped anywhere else.. Thanks for your help..
Old Oct 14, 2008 | 12:00 PM
Hayashi's Avatar
Open the air box and spray in some starting fluid with throttle OPEN. Then CLOSE the throttle and try to start the engine with the choke FULLY on.
Old Oct 14, 2008 | 09:32 PM
I'll give that a shot.. Thanks
Old Oct 26, 2008 | 07:44 PM
Hayashi,
Tried what u advised and still no luck.. Anymore ideas would be appreciated.. Thanks
csmith33slb
prarie-dog
Dec 5, 2001 11:46 PM
D84
Nov 18, 2001 08:28 PM
wrefer
May 12, 2000 05:06 PM
prarie-dog
Feb 9, 2000 05:53 PM
