Brute Force: LOOSENING Steering Connection
Old Oct 15, 2008 | 07:49 PM
bradjacob's Avatar
Default Brute Force: LOOSENING Steering Connection
I have a 2006 Brute Force 650i. There are two rods that connect the front wheels to the coupler on the steering column. They are held together with 2 jam-nuts and a cotter pin. One of these nuts loosened. I tightened it up (had to pull the cotter pin to hold the BOLT because it spins). After about 2 hours of riding, it loosened again.
Is this a common thing, or is the jam-nut one of those things where it's a "one-time" use? If it loosens, does that mean that its compromised, and time for a new one?
And the fact that the bolt spins - is that normal?
Old Oct 16, 2008 | 11:56 AM
bradjacob's Avatar
Bump... Anyone got any insight on this problem?
Old Oct 17, 2008 | 09:26 AM
Starvin's Avatar
My 05 Brute 750 is in the shop now for a tie-rod recall that i guess is common. May want to talk to youre dealer to see if the recall applies to your model too.
Old Oct 17, 2008 | 11:52 AM
Hayashi's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Starvin
My 05 Brute 750 is in the shop now for a tie-rod recall that i guess is common. May want to talk to youre dealer to see if the recall applies to your model too.</end quote></div>
That recall is for the ball/socket joint being loose.
The OP's issue is the jam nut coming loose, not the same problem.
Try applying thrad locking agent.
95wolv
Sep 27, 2024 12:00 PM
mongeon
3) General Discussions..
Oct 6, 2015 02:27 AM
Sw00p
Sep 24, 2015 02:50 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
