2002 POLARIS 500 ho rear bearing and removal ???
Old Oct 17, 2008 | 10:04 PM
manxman's Avatar
Default 2002 POLARIS 500 ho rear bearing and removal ???
I am in need of a rear bearing number for my 2002 POLARIS 500 ho .When I was replacing the boot on the rear cv I noticed that the bearing assembly had come apart half was on the cv the rest was in the outer rear assembly.If someone could give me a number for the rear bearing it would be great.Would these be the right ones
Napa # FW143
Advacned Auto # 51013
Old Oct 17, 2008 | 10:20 PM
Can go with OEM or EPI which is about half! Cant remember prices,just overheard our parts guy ordering for a customer. I'm like a mushroom on parts prices,stuck in the dark and fed bull****! Good luck
Old Oct 17, 2008 | 10:30 PM
TLC's Avatar
TLC
Part # 3585502 about $65.
Old Oct 18, 2008 | 10:11 AM
colt2245p's Avatar
go to a auto parts store and get a front wheel bearing for ford escort years from 91 to 99 i think. they sell several grades of these. i have used many of them from 01 500 to 06 800 for the rear. u will pay anywhere from 20 to 40 bucks each.
Old Oct 20, 2008 | 12:08 PM
manxman's Avatar
I have tapped on the relief in the inner part of the carrier the inner bearing is out already and I have removed the outer clip.If I tap on the relief on the inner part of the carrier will the outer bearing come out also .I'm thinking I should remove the carrier and use some heat to get it out.Could someone help me any info would be good.What method does anyone recomend.In the manual it says to tap on the relief in the inner carrier and the bearing will come out I've tapped on it but I am reluctant to give it a good bang from what I've read a tap is all it should need any info would be appreciated.
Old Oct 20, 2008 | 12:21 PM
colt2245p's Avatar
i take the hub off, remove large snap ring, lay if face down on a block of wood and use a large socket and drive it thru till it hits the wood, then support it on the edges and continue driving it out. yes it will take several good whacks to get it going. make sure after you remove snap ring clean the groove and all dirt from around bearing before you start. to reinstall, put the new bearing in freezer for a while. heat the housing gently with a propane torch for about 5 minutes then quickly install new bearing.
Old Oct 21, 2008 | 01:17 AM
manxman's Avatar
The inner part of the bearing is out it more or less fell apart.The only thing in the hub is what the ***** run in so if I get a big enough socket that will sit in where the ***** use to run in and give it a good wack it will come out??
Old Oct 22, 2008 | 08:23 AM
manxman's Avatar
I got the bearing out very much appreciated for all the help .I'm going to pick a bearing today.Thanks again and I'll let you know when it's back together.
gfl0224
Jun 27, 2015 06:52 PM
hoopduerr
Jun 10, 2015 03:00 PM
Dakosk
Jun 6, 2015 05:37 PM
volsgo30
Jun 4, 2015 06:07 PM
hoopduerr
Jun 2, 2015 09:01 AM
