warrior problems
Old Oct 21, 2008 | 02:11 AM
arandall's Avatar
Default warrior problems
i have a 2001 warrior, when i start it up it idols fine, but when i try to rev up it spits and sputters.....BUT, when you bounce up and down on the bike it revs up fine and will ride fine until the rpm's are lowered, then it starts again. the parking brake has already been disconnected so it can't be that.
It has been doing this for a while but it was running just fine for about a week and just started again today, so i purchased a rebuild kit for the carb. Any other ideas???
Old Oct 21, 2008 | 09:45 AM
DOCPHIL's Avatar
DISCONNECTING THE PARKING BRAKE CABLE COULD BE YOUR PROBLEM THAT WARRIOR HAS A REV LIMITER THAT PREVENTS THE ENGINE TO REV UP WHILE THE PARKING BRAKE IS ON. THE SWITCH THAT ACTIVATES THE REV LIMITER IS ON THE CLUTCH LEVER ASSEMBLY. TRY PUSHING THE MECHANISM IN THAT PULLS THE CABLE FOR THE PARKING BRAKE( PUSH IN THE SAFTY SWITCH) IVE READ ON HERE THAT YOU CAN CONNECT THE WIRES TOO BUT NEVER TRIED THAT)
Old Oct 21, 2008 | 11:54 PM
arandall's Avatar
i read through these forums and everyone is saying that is what you need to do, "disconnect the parking brake". this has already been done before i bought the bike. any other suggestions????
Old Oct 22, 2008 | 12:40 PM
91Warrior357's Avatar
you disconnect the wires and then plug them into eachother, but it seems like maybe you have a carb problem, maybe your fuel bowl is getting stuck or is at the wrong level
Old Oct 23, 2008 | 02:48 AM
Andrew's Avatar
did it run good after?
Old Oct 24, 2008 | 02:33 PM
josephh's Avatar
you might have a short in the brake light that causes the silinoid to stop produding juice but when you bounce up and down on it it pulls the naked wires apart or you might have warter in the gas hopes this helps and god bless
Old Oct 29, 2008 | 10:56 PM
arandall's Avatar
alright, just put a new carb on, and when i started it, it was still doing the same thing, so i just nudged a few wires behind the battery box and it started revying real high so i turned it off and put them back where they were, now it wont start????
Old Oct 30, 2008 | 01:58 PM
beefy46172's Avatar
Loves To Ride!
You need to inspect your wiring harness then. Sounds like you've got a wire or two with the insulation rubbed off and they are shorting out.
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Reactant
Jul 16, 2015 10:29 PM
