350x hard to start
Old Oct 21, 2008 | 05:57 AM
jjcava's Avatar
Default 350x hard to start
have 1986 honda 350x have to kick forever to get it started anyone have any suggestions jjc
Old Oct 22, 2008 | 11:17 PM
Jbridered's Avatar
Engine cold or hot? Maybe valves. Put a hair dryer on your exhaust and heat the engine head up for a while. If it starts easy afterwards adjust your valves.
Old Oct 22, 2008 | 11:34 PM
250arrrr's Avatar
Also, check the decomp lever. If its hung open you will kick forever....
Old Oct 24, 2008 | 11:21 AM
scary132's Avatar
Do you still have the stock jetting? They are pretty lean stock. I went up one size on the pilot jet (48 I think) and it starts so much easier. One click on the choke when cold. I went one up on the main jet too (160 I think) even with the stock pipe, you'll be surprised how much better it runs, especially in cold weather.
All assuming your compression and spark are good and valves are adjusted and decompression working properly.
Old Oct 24, 2008 | 10:12 PM
jjcava's Avatar
just bought bike once it's running it starts better after i kick when it's cold i pulled out the plug and it is dry no smell of gas choke is closed also
Old Oct 25, 2008 | 12:53 AM
scary132's Avatar
Is the motor stock as far as you know? Pipe? Air filter? You need to take the carb off and clean it/blow out the jets and passages. See how it is jetted. Check the mixture screw, stock setting is 1 3/4 turns out from seated. Once you know the carb is clean and set, filter is clean, put a new plug in.
To kick it.... Push the kick starter slowly all the way down first, bring it back up 3/4 of the way, then kick it hard as you give the throttle a little push.
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
Ty Speece
Jul 2, 2015 04:59 PM
1000gade
May 27, 2015 12:37 PM
dunc_n
Aug 26, 1999 09:32 PM
