Post-Wash Backup problems
Old Oct 22, 2008 | 08:39 PM
war1ock's Avatar
Default Post-Wash Backup problems
Well ive got my 96 TB 250 and whenever i was it and let it dry to almost compeltely dry if i try to back up even while holding the Override button when i get up to like 3 mph it will drown out like im not holding the OR button. After i let it set overnight it will backup fine. This is the second time its done this. Not really a big problem jsut curious to what causes it and what its doing.
Old Oct 22, 2008 | 09:17 PM
eggenz7's Avatar
unplug the black wire on the rev limiter. no more override button needed and gets rid of the problem. more than likely water is getting into a connector somewhere. you could take the connectors apart and spray with contact cleaner then spray with dielectric grease to waterproof them
Old Oct 22, 2008 | 09:35 PM
war1ock's Avatar
if i unplug the rev limiter will it stop from boggin in only reverse or will it let it get too high in Forward too?
Old Oct 22, 2008 | 09:37 PM
trailblazer_02's Avatar
you can just disconnect the override and not have to use it when backing up?
and it has no negative effects ?
Old Oct 22, 2008 | 09:38 PM
eggenz7's Avatar
just controlles what the button would normally control. the cdi box controls the normal RPM limits. the rev limiter is a *safety feature*
Old Oct 22, 2008 | 09:41 PM
so if i disconnect it, it wont do anything except make it to where i dont need to push the button when backing up?
cause i got a problem with using that button. i have to have someone else hold my drink [img]i/expressions/face-icon-small-wink.gif[/img]
Old Oct 22, 2008 | 09:46 PM
eggenz7's Avatar
thats right. unplug the black wire and no need for an override button. they generally end up going bad anyways.
Old Oct 23, 2008 | 02:25 AM
CaptainQuint's Avatar
My reverse override switch has a leak in it somewhere. If I wash it or get it extremely wet and I press the override button it dies. Once it dries out for a bit then it's fine. After I wash it I have to drive it down the road a bit at high speed to dry it out. Being a gravel road it doesn't do much for the new washjob of course.
Old Oct 23, 2008 | 05:11 AM
user493's Avatar
Moto Psycho
I've never had a single problem with a rev overide button. None of my friends have either. They don't just "generally end up going bad" IMO, and I store my ATV outdoors year-round. If you pressure wash it, against Polaris' instructions, all bets are off.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
