front recon brakes
Old Oct 24, 2008 | 11:28 PM
Hawkman300's Avatar
Default front recon brakes
its an 05 honda recon used, but only got 30-40 hours on it from the previous owner. the back brakes are great and can lock. the front brakes are crap. theres WAY too much freeplay before the brakes start to take hold, and i think that is the problem. ive tried jacking up the front end with the front wheels off the ground and adjusting the drum brakes and they were both adjusted correctly. is there any way to adjust the brake linkage or anything like the rear brakes?
Old Oct 25, 2008 | 10:26 AM
colt2245p's Avatar
not being a smarty a$$ but they are not adjusted correctly, or they are full of dirt or worn out. did you adjust BOTH adjusters on EACH side on only one?
Old Oct 25, 2008 | 12:46 PM
Y2daT's Avatar
dennis kirk ,and some other websights have the disk brake conversion kit I think they run around $300.00
Old Oct 26, 2008 | 09:57 AM
Hawkman300's Avatar
well i just got this atv 3 weeks ago, so i dont know much about it and dont know much at all about drum brakes. idk how you could adjust the front brakes since it isnt like the linkage for the back brakes. and i adjusted both brakes and they both are, and were, adjusted correctly. im not spending any money on this either, so if i cant fix them then ill just live with it.
Old Nov 12, 2008 | 04:08 PM
Hawkman300's Avatar
this weekend was looking at the front brake lever and that area just checking it out and got an idea: where the lever pushes that little metal button looking thing for the brakes to work, i just stuck a couple washers in there and front brakes work great now. any problems i might have with this? it doesnt "bottom out" or anything like that, so i dont think it would be hurting anything.
Reactant
Mar 30, 2022 02:08 AM
timster911
Jul 13, 2015 01:57 PM
tporath
Jul 11, 2015 12:31 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
MNatv89
Jul 7, 2015 11:36 AM
