Fabric to use when covering a seat.
Old Oct 27, 2008 | 11:33 AM
MonkOFox's Avatar
Default Fabric to use when covering a seat.
I'm wanting to make a custom seat cover for my trike (red on the sides and white down the middle). What fabric or material should I buy (water resistant and easy to clean) to ensure the the seat lasts a good while?
Thanks,
Justin
Old Oct 27, 2008 | 11:04 PM
scary132's Avatar
marine grade vinyl
Old Oct 28, 2008 | 02:33 PM
oldmanriver's Avatar
I just recovered my seat on a 185. I used marine grade vinyl to do it. Also re did the foam as well. Basically just used the old foam and added another layer to it. I used the 3M spray glue to add the layer. To attach the fabric, I used the spray glue also. I sprayed both the foam cushion and the back of the vinyl, let them get tacky and then formed the vinyl around the foam and seat pan. To get rid of those ugly corners where material like to bunch up. I very carefully used the heat gun to make the vinyl form around the corners. Mine turned out awesome. Just takes some time to do is all.
Old Oct 29, 2008 | 12:11 AM
MonkOFox's Avatar
sweet, thanks for all the info.
Justin
Valder
Nov 28, 2020 07:38 AM
Joe454
Nov 20, 2020 01:19 PM
ReconBayou
Oct 16, 2019 02:24 AM
buddieboy
Dec 9, 2016 05:50 PM
jbrewster94
Sep 23, 2015 04:16 PM
