99 Sportsman 335
Old Oct 28, 2008 | 08:07 PM
hoss298's Avatar
Default 99 Sportsman 335
Bought new in "99, only 1500 miles, carb rebuilt, runs great for several miles then starts bogging down, HELP
Old Oct 28, 2008 | 08:45 PM
ardakota's Avatar
just dealt with one there is a service bullitin by polaris the air breather tube that goes up by the gas tank is probably sucking to the gas tank and blocking the air off. It needs to be took off and cut at an angle to where it cant suck to the gas tank. i think that shoud be the first thing you should look at. And those 335s wont run right without the breather cove on and sealed right. Hope this helps.
Old Oct 28, 2008 | 08:52 PM
hoss298's Avatar
Thankx for the info, if that's all it is that'll be great
Old Oct 28, 2008 | 08:55 PM
ardakota's Avatar
does it run good except when you start getting into it into a pull my friends ran great at idle and nearly halfway throught the throttle but when you started to need a little mor power for a pull it would just bog down.
Old Oct 28, 2008 | 09:00 PM
hoss298's Avatar
It runs great for several miles at all speeds from idle to full throttle, then for unknown reasons it'll just start bogging down to where you have to keep "feathering" the throttle to keep it going
Old Oct 28, 2008 | 09:07 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
is it flooding out or starving for gas? did you make sure the air filter is good and not being blocked as well as all the vent lines? when it does it next time try removing the gas cap to se if its under presure as well. did you make sure to set the float level correct when the carb was redone? just a few ideas.
ardakota's Avatar
i would sure check that tube cause my friend spent several dollars on thos carb parts, fuel pump and coil with the age yours is its probably about that time ithat tube messes up.
Old Oct 28, 2008 | 09:18 PM
hoss298's Avatar
It's flooding out, strong gas odor, thankx for the advice
Old Oct 28, 2008 | 09:20 PM
hoss298's Avatar
I'll definitely check the air snorkel, thankx again!
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
