99 Sportsman 335
99 Sportsman 335
just dealt with one there is a service bullitin by polaris the air breather tube that goes up by the gas tank is probably sucking to the gas tank and blocking the air off. It needs to be took off and cut at an angle to where it cant suck to the gas tank. i think that shoud be the first thing you should look at. And those 335s wont run right without the breather cove on and sealed right. Hope this helps.
99 Sportsman 335
is it flooding out or starving for gas? did you make sure the air filter is good and not being blocked as well as all the vent lines? when it does it next time try removing the gas cap to se if its under presure as well. did you make sure to set the float level correct when the carb was redone? just a few ideas.
chingchangchong
08-07-2022 11:36 AM
slowgsxr97
09-08-2015 07:33 PM
cdstang
08-31-2015 07:52 AM
