I need help with electical problem
Old Nov 5, 2008 | 08:11 PM
amlm214's Avatar
Default I need help with electical problem
I have a 03 sportsman 500 ho. It runs fine but when it warms up all the lights, insterment cluster, everything electical starts to strob on and off. I already put a new rectifier in it but no help. I know micanical stuff not electial. A friend said try cleaning the stator. Is it behind the pull starter. thanx
Old Nov 5, 2008 | 09:09 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you check the voltage out put to see what it is when running. try that when it starts doing it. make sure its not shorting out some where as well.
Old Nov 6, 2008 | 12:25 AM
Fordby4's Avatar
My 600 sportsman was doing the same thing. Old Polaris tech told me to check the black sealed pouches in the wiring harness under the hood. The relays in these pouches were rotted any very badly rusted. Replaced them and eveything works fine. Check to see if you have these so called 'sealed' pouches, cut them open and have a look.
Old Nov 6, 2008 | 07:52 PM
amlm214's Avatar
do you have to reseal them some how and thanx I will take a look
Old Nov 6, 2008 | 09:08 PM
If you trace problem down to thermal fuses in the plastic covers and corroded as posted above, replacement fuses comes with sealed pouch and wires on both sides that you just splice back in.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
