honda 250r atc bore info needed
Old Nov 10, 2008 | 07:46 PM
TimberedWolf250's Avatar
Default honda 250r atc bore info needed
I see the stock bore on the cylinder is 70.mm
I measured it with my calipers it showed 2.836 inches when I convert that to mm it comes up as 72.0344 mm
which is about .080 over can I go larger do they make a .090 thousands over piston and ring kit?
thanks
Old Nov 11, 2008 | 11:54 PM
250arrrr's Avatar
80 over is all thats offered. I got lucky on ebay once and found a old 74mm piston. It worked out but made the walls rediculously thin. I have 2 stock bore cylinders for the 81-84 250r's. Once cleaned up they would be 20 over(or 10 if u can find that piston)...
Old Nov 12, 2008 | 10:25 PM
want to sell a good 250r atc cyclinder?
Old Nov 13, 2008 | 12:13 PM
250arrrr's Avatar
pm sent. dont want to get into a classified ad here.....
Old Nov 13, 2008 | 05:21 PM
Thanks for the info.
I think I am going to sell my 250R
How do I post in the classified here?
it is a 198? Honda 250R $280.00 needs piston and cylinder or sleeve in cylinder
Old Nov 13, 2008 | 05:23 PM
250arrrr's Avatar
i think u have to be a supporting member to post. i wish u were closer to me...
Old Nov 18, 2008 | 08:58 AM
cascade quadracer's Avatar
just send your jug to LA sleeve and get it done right. then sell it for alot more. BTW where are you located?
Old Nov 18, 2008 | 09:22 AM
located in Missouri
neilbedwell
Nov 10, 2018 11:02 AM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
Berjr
Jun 15, 2015 04:41 PM
lovinhonda
Jan 25, 2000 09:17 PM
