warrior help
Old Nov 12, 2008 | 02:08 PM
userfriendly's Avatar
Default warrior help
my 95 warrior is dragging while i try to start it. ive changed the starter, battery, even checked the valve lash. are these motors likely to jump time?
when i try to turn it over it drags for about 10 sec (whining sound) then slowly turns over. now it wont even start. ive even tried a car battery with the same result.
any help is appriciated
Old Nov 12, 2008 | 04:55 PM
91Warrior357's Avatar
it sounds like a starter clutch problem, left side cover pull it off and see if andything is undone or broke
Old Nov 12, 2008 | 07:17 PM
where is the starter clutch exactly?
Old Nov 12, 2008 | 08:47 PM
on the left side of the engine in between the starters gear and the flywheel. its just a shaft with a small and a big gear the starter turns one gear which turns the other gear which turns the flywheel and turns over the engine
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
