84 Honda 200s Carb question
Old Nov 20, 2008 | 02:00 AM
Chad711's Avatar
Default 84 Honda 200s Carb question
I ordered a new carb for my 3 wheeler. I installed it today, but where does the line that is on the bottom of the carb go to, and also there is a port to the left of the actual fuel line (that comes from the tank), what goes there? They dont go together do they? I tried starting it and fuel was coming out that port on the side. I didnt have an old one to compare to unfortunately, and the new one came with NO instructions.
Thanks, Chad.
Also, there is a lever with a cable on the top right side of the cylinder head, and that cable is not attached to anything. Where does it goes and what it it? I can take pictures if needed.
Old Nov 20, 2008 | 07:09 AM
HondaMechanic's Avatar
Old Nov 22, 2008 | 08:37 AM
Chad711's Avatar
The idle speed is the jet on the right side correct? What is the lower jet, a mixture? It is running great got it going last night, but I wanted to know what that lower jet was for. Thanks, Chad. Also any ideal what that lever on the right side of the head is for? The cable goes nowhere, it did go to some lever at some time I just cant tell where.
Old Nov 22, 2008 | 11:33 PM
pcollins's Avatar
theres the throttle cable, then it might have a choke cable as well.
Old Nov 23, 2008 | 03:29 PM
scary132's Avatar
That lever is for the decompression cable. Idle speed it the screw with the spring on the right side. The screw on the bottom is the mixture screw.
Old Nov 23, 2008 | 09:09 PM
Chad711's Avatar
Thanks, what is a good start point for the mixture (turns out). Its running great put 15 miles on it riding some trails. So I really dont need that cable, thats for starting right. It starts easy as is.
Old Nov 24, 2008 | 11:48 AM
scary132's Avatar
I have a 200E manual, which looks like the same carb. Says to turn the pilot screw in until it seats gently then 1 7/8 turns out as a starting point. Yes it is for starting. I've never used it either.
Old Nov 24, 2008 | 02:24 PM
Chad711's Avatar
Thanks for the info.
neilbedwell
Nov 10, 2018 11:02 AM
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
VRRRRT
Jun 27, 2015 09:38 AM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
lovinhonda
Jan 25, 2000 09:17 PM
