Troubleshoot no reverse problem...
Old Nov 22, 2008 | 06:09 PM
willyd1's Avatar
Default Troubleshoot no reverse problem...
There seems to be no reverse gear, the lever just moves and feels like it doesn't touch anything. Does anyone know how to troubleshoot this problem. Thanks ahead, Bill.
Old Nov 22, 2008 | 06:16 PM
TLC's Avatar
TLC
Take rods off tranny, shove it into reverse by hand at the tranny lever. If it goes into reverse than you know its just the rod adjuster have to be reset.
Old Nov 22, 2008 | 06:23 PM
<div class="FTQUOTE"><begin quote>Originally posted by: willyd1
There seems to be no reverse gear, the lever just moves and feels like it doesn't touch anything. Does anyone know how to troubleshoot this problem. Thanks ahead, Bill.</end quote></div>
Very possible reverse actuator bad,try pulling lever on actuator on right side of transmission and see if goes into reverse.IF SO then new one needed. Have replaced a couple over the years. Good luck opt
Old Nov 22, 2008 | 06:24 PM
willyd1's Avatar
ok , now I am a truck mechanic. I am unclear about what rods and tranny lever ?? There is a part you put your foot on to shift connected to a rod that goes inside the case. Thats it. Sorry about the confusion.
Old Nov 22, 2008 | 06:44 PM
ok , now I am a truck mechanic. I am unclear about what rods and tranny lever ?? There is a part you put your foot on to shift connected to a rod that goes inside the case. Thats it. Sorry about the confusion.</end quote></div>
[img]i/expressions/face-icon-small-happy.gif[/img] AGAIN,pull/ push reverse actuator lever(black box on right side of trans with small lever) to see if reverse gear engages as you push foot shift!!!!
Old Nov 22, 2008 | 09:40 PM
scrambler400enoge's Avatar
Shapeshifter Rider
I had that issue.rebuilt the carb and poof had reverse!
Old Nov 23, 2008 | 01:08 AM
willyd1's Avatar
Thanks guys, it is the actuater.
vandammages@gmail.com
Aug 20, 2020 11:50 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
ReconBayou
Oct 16, 2019 02:24 AM
EIF
Apr 20, 2017 07:15 PM
r1pilot83
Sep 27, 2015 07:38 PM
