Skid Plates
Old Nov 23, 2008 | 03:02 PM
Bedrock's Avatar
Default Skid Plates
We just bought our son a 2007 Honda 250 Recon.... He is interested in skid plates for it. Has any one purchased any from a reputable company?
Thanks
Dan
Old Nov 23, 2008 | 09:54 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
Default Skid Plates
Try Rockymountainatv.com
Old Nov 23, 2008 | 11:35 PM
Y2daT's Avatar
Default Skid Plates
Ive had good luck on ebay and ive ordered from rockymtatvmc and denniskirk
Old Nov 27, 2008 | 10:23 AM
sporter's Avatar
Default Skid Plates
Aluminum Products, Inc,, great product easy install on my Rubicon,
Old Nov 27, 2008 | 11:58 AM
fogle22's Avatar
Default Skid Plates
I was in the market for a skid plate for my '06 Rubi, but a local ATV guru told me not to install the skid plate. He said the frame and placement of the vitals would make it near impossible for anything to cause damage. He felt the skid plates offered little to no additional protection, just added weight and reduced performance. He said that sticks will get stuck in the arm plates and puncture the boots.
He also said it will cause rusting on the pipe framing due to the U bolts rubbing the protective coating off.
Just a thought so you can make an informed decision. FYI...he sells ATV parts, so he basically talked me out of a $350 sale.
Old Nov 28, 2008 | 09:24 AM
Y2daT's Avatar
Default Skid Plates
i would judge if you need them or not based on where and how you ride ...personaly i like skids cuz i hit everything and ride it like i stole it
Old Nov 29, 2008 | 10:18 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default Skid Plates
I used a light plastic one from Maier for the chassis, and kept the stock one on the rear final drive. http://www.maier-mfg.com/
Don't laught at the plastic! It is very durable and is slick and doesn't gaul and hang up on rocks like aluminum does. Remember, they make guns out of plastic these days!
As far as the rear end, all the skid plates I checked out reduced the ground clearance considerably, so I stuck with the stock one but have to change it out now and then, because it really isn't very heavy duty.
Check Rocky Mountain for other options. I usually run DG skids on my other quads.
Old Nov 30, 2008 | 12:16 PM
Y2daT's Avatar
Default Skid Plates
my 250x has a plastic belly skid .its held up fine for me ,and i abuse the heck out of that machine..like forging trails ,and crossing big downed trees were i have to weelie so my belly plate hits then the momentum carrys me over the tree
lonerider856
Oct 13, 2023 03:45 PM
Alex G.
Sep 11, 2017 11:38 PM
Oct 10, 2015 10:20 AM
tysonbully
Sep 28, 2015 02:30 AM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
