Smoking sometimes
Old Nov 26, 2008 | 12:05 AM
500H.O.'s Avatar
Default Smoking sometimes
My 03' s.p.500ho smokes when i start it up after it sits for a few days, then after I run it for about 20min it don't smoke at all. What could this be? Should I be worried? The bike still has good power and dosn't knock. Will it get worse? Should I rebuild? Any help would be nice , thanks.
Old Nov 26, 2008 | 12:30 AM
lobodog3's Avatar
Doe.....
Valves and or valve seals
worry maybe
worse yes it will get worse
replace the valve seals and or valve job
Old Nov 26, 2008 | 06:59 AM
If taking head of might as well check/replace rings as could be having blowby(oil getting past rings into combustion area) and burning until warm and rings then seal. Kinda early to be smoking unless oil changes infrequent or different oil used than recommended.
Old Nov 26, 2008 | 07:05 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
chances are the valve seals are getting a little bad. alot of vechicles do that. key an eye on the oil level and chage it if it hasnt been done in a long time. unless it gets real bad i wouldnt woory too much about it. imo.
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
EIF
Apr 20, 2017 07:15 PM
CosmoM
Sep 21, 2015 04:57 PM
bvolks
Sep 13, 2015 12:57 PM
