Battery Not Charging?
Old Nov 27, 2008 | 05:27 PM
dodge33's Avatar
Default Battery Not Charging?
I just bought a new 2007 polaris sportsman 700 from sport rider in morgantown. the second time i had it out, i noticed that the battery was blinking on the screen. So i checked the voltages coming off the battery. it was only like 11.5 i think. Then i charged the battery and started the atv back up and the voltage across the terminals did not change? i even reved the engine up, and the voltage didn't change at all? Is there an alternator or something that charges the battery? What can i check? Please help!!! this is my first atv and it is not looking too good!!!!!!!! thanks..................................Dan
Old Nov 27, 2008 | 05:32 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
check the connections on the ecm which is also the recifier that controls the voltage going into the battery. if you check the volts w/ it reving it should be above 13.5 at the lowest. if the charging system isnt working im guessing its the recifier thats the issue. imo.
Old Nov 27, 2008 | 05:40 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
here is the part numbers on the regulator.
4011925 Regulator [If built after 1/22/07]
4011569 Regulator [If built before 1/22/07]
Old Nov 27, 2008 | 05:43 PM
dodge33's Avatar
i am VERY NEW at this. i am looking in my manual trying to figure out what and where the ecm is located. and also the recifier? i am sorry but i am not sure what those are?
Old Nov 27, 2008 | 07:10 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
unless you have a service manual and not an oweners manual it wont say anything about them in there. its up under the front end under the plastic square in sahpe a w/ harness going into it.
Old Nov 28, 2008 | 01:27 AM
dodge33's Avatar
ok, i guess i will ahve to get me a service manual since the cheap people (sport rider) didn't give me one with the atv! thanks for the info!
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
Pahuntman
Sep 5, 2015 11:07 AM
scram5050
Sep 3, 2015 05:06 PM
