more 4x4 problems
Old Nov 29, 2008 | 01:02 PM
big_kid's Avatar
Default more 4x4 problems
ok, more problems. had a wheel bearing go bad due to seal bad and leaking all fluid out of the hub. i replaced all the bearings (8 total) with new seals and new fluid. now more times than not the front hubs engage even when the demand switch is turned off. seems it dosent happen as much if the axle nut is loosened some, but then the hub has too much slop in it. some times its the right side sometimes its the left side. it has me baffled. any help appreciated. thanks....
p.s. this is a 2001 explorer
Old Nov 29, 2008 | 02:11 PM
TLC's Avatar
TLC
Axle Nut can never be tighten beyound 144 in/lb for the Hillary to work properly.
Old Nov 29, 2008 | 03:13 PM
MECHANIKE's Avatar
cant have too loose either,make sure all the metal is out.armiture plates are flat and not wavy.hub fluid or type f trans fluid filled so it leaks out at 9 or 3oclock position.
Old Nov 29, 2008 | 06:27 PM
big_kid's Avatar
ok, took everything apart again, cleaned, and new fluid. backed off on the axle nut another 1/2 turn and same problem. with the 12volt hub wires disconnected i can put it in reverse and give it some gas and the rear wheels will spin about 10 times then WHAM one side engages and rips the handlebars out of my hands....
i seen some wear on the armature plates but i dont know if this is the problem or not...
Old Nov 29, 2008 | 06:51 PM
big_kid's Avatar
ok, it helps to look in the book when all else fails. having this thing down so long i forgot to reinstall the spacers that go between the outer strut bearing and hillard cam. ive looked everywhere and cant find them. part # 1321814 anyone got any....
HEHEHE
Old Dec 9, 2008 | 10:14 AM
deadman45's Avatar
Depending on what style hilliard you have you don't need a spacer. if you torqued on a axle nut that needs a spacer you probably could'nt turn the hub. If the armature plate becomes magnetized,then you have to change them. That comes right out of a service bulletin from polaris
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
