4 wheel drive
Old Dec 2, 2008 | 08:34 AM
Jeff2053's Avatar
Default 4 wheel drive
Does anyone have any suggestions my 4 wheel drive does not work it will engage once in a while but when it does engage the 4x4 indicator light does not com on. The battery seems to be good, light are bright, winch works fine picking up my plow, engine cranks. that being said I did put the battery on charger and made sure it was top off made no difference. Any direction would be appreciated as where to look next
Thanks
Jeff
Old Dec 2, 2008 | 09:18 AM
onesavage's Avatar
possible problems in the frt diff,i have replaced 3 cracked hillard cages in my 04.5 ..not a fun job and pricey
Old Dec 2, 2008 | 05:48 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Change front end fluid.
Old Dec 3, 2008 | 08:09 AM
Jeff2053's Avatar
Can anyone tell me where tah all wheel drive coil is located? I started the machine up in diagnostic mod and its telling me that the all wheel drive coil is off and the manual says that means its not getting any voltage to it. The battery is in good shape
Thanks Jeff
Old Dec 3, 2008 | 11:01 AM
TLC's Avatar
TLC
Does it have the two hub Hillard's or the one front diff Hillard with the plastic cage?
Old Dec 3, 2008 | 11:35 AM
Jeff2053's Avatar
NOT SURE HOW DO I TELL
Old Dec 3, 2008 | 11:40 AM
TLC's Avatar
TLC
What year and model of ATV is it?
Old Dec 3, 2008 | 12:09 PM
Jeff2053's Avatar
2004 1/2 SPORTSMAN 700
Old Dec 3, 2008 | 12:17 PM
TLC's Avatar
TLC
I,m sure that has the single front diff engagment, so the weak plastic roller cage is a concern to look at. One of Polaris changes for the worst ,not better.
If it turns out to be so, John Dear offers a stronger metal roller cage that will work.
jrubicon
Where to Ride
Oct 8, 2015 01:05 PM
cody500ho
14
Aug 14, 2015 05:03 PM
toonces
Aug 5, 2015 05:55 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
rcappie4
Jul 18, 2015 07:51 AM
