4x4 PROBLEM
Old Dec 4, 2008 | 12:54 AM
HARLEY_OWNER's Avatar
Default 4x4 PROBLEM
ok one of my wheels quit spinnin today i noticed... and after lookin over the bike i noticed the CV boot was tore ... would that make the 4x4 quit working? would the fluid in the hub leak out? or what? thanks guys... and by the way i just had the WHOLE 4x4 gone through... everything inside was replaced
Old Dec 4, 2008 | 07:20 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default 4x4 PROBLEM
no a torn bot would cause it to stop working. more then likely something inside the hub but you will need to replace the boot for sure. imo.
Old Dec 5, 2008 | 12:57 AM
eggenz7's Avatar
Default 4x4 PROBLEM
if you striped a cv joint it would stack the 4x4 from working on that axle.
Old Dec 5, 2008 | 06:38 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default 4x4 PROBLEM
if you did that you should be able to hear and see it w/out too much issue. there would be alot of slop in the cv cup for sure. imo.
Old Dec 5, 2008 | 11:30 AM
MECHANIKE's Avatar
Default 4x4 PROBLEM
you need to check fluid level,only holds a few ounces,check for any wheel play with hands at 12 and 6 0clock.play even a small amount is bad cause the three tangs on the armiture plate are only about 1/8"+tops long and wide,which leaves no room for slop,they will spin and completely take out(and not to dinner) the hilliard roller clutch.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
