300 explorer
Old Dec 5, 2008 | 04:20 PM
Beau49's Avatar
Default 300 explorer
It is a 1996 300 explorer and it was running great the only reason I changed the filters is because the Air filter you couldn't even see light though it when you held a bright light right up to it. We are talking filthy as can be.
So I figured I would change the little in-line gas filter and put a pre filter on it since it didn't have one on it when I bought it. I have to say it sure sounds different with out the old dirty air filter in it but the problem is when you go to open it up it just want to fall before it takes off.
Before I changed any of the filters if you push the throttle the darn thing would take off but not now. Could it be the air/fuel mixture is messed up now? If it is how hard is it to adjust it? It didn't come with a manual but I have been looking at the one for the 1998 300 explorer and the dealer I buy parts from which is along ways away said that the 1998 is the same expect for some of the decals.
Just thought I would check with some of you Guys/Gals that have alot more experience with ATV'S than I do this is my first one. Having a blast with it but finding out it is going to take a lot of MTX.
Thanks in Adance!!
Old Dec 5, 2008 | 09:09 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it could be that the pre filter is cutting the air off enoguh to make it run rich and fall on its face. unles someone had adjusted the air screw i wouldnt think it could be. how does the plug look? the gas filter is on the right way(arrow toward the gas flow)? you didnt get any dirt in the carb when you changed the filter? just a couple of ideas.
Old Dec 5, 2008 | 10:33 PM
Beau49's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: stendori
it could be that the pre filter is cutting the air off enoguh to make it run rich and fall on its face. unles someone had adjusted the air screw i wouldnt think it could be. how does the plug look? the gas filter is on the right way(arrow toward the gas flow)? you didnt get any dirt in the carb when you changed the filter? just a couple of ideas.</end quote></div>
The Plug looks clean, I made sure I was careful about dirt in the carb. I double checked the fuel filter to make sure it was on the correct way.
I ran it a little more this afternoon and it seemed to be running some what better. Hoping to get it out to the farm tomorrow so I can give it a good test run.
Old Dec 5, 2008 | 10:53 PM
Racing Josh 's Avatar
Hi, I have a 1996 Polaris 300 express 4x2 and i am searching for head lights and the harness that connects the lights. I just started searching can anyone point me in the right direction????? Thanks
Old Dec 5, 2008 | 11:09 PM
eggenz7's Avatar
search ebay. that is your best bet for cheap used parts
mattcraig1
Aug 26, 2015 03:08 AM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
WIscrambler
Jan 22, 2001 07:32 PM
tomuchfun
Feb 26, 2000 10:07 AM
keithb
Sep 13, 1999 10:09 PM
